So I picked this engine up in a semi dis-assembled state, they were beginning the tear down to replace the rings. They ended up not having the time/money for it so i bought it. I tore it down the rest of the way, and honestly this engine looked alright, bearings looked good, although the oil was a little bit dark.
At this point every part has been scrubbed and degreased, from the oil pan all the way up to the valve springs and retainers. The only thing that hasn't been fully cleaned is the exterior of the block. After it is all said and done, the bores looked great, no scuffs, same with the pistons. The cams and rockers didn't look wiped out at all. Here is a shot of all the big parts laid out:
Head all stripped and cleaned:
And the valve train:
I bought it thinking that it might go into my car one day, but most of you have probably seen my stolen and for sale threads. Since I don't have a car to put this into any more, but I enjoy building engines I figured I would build this up and post some pictures of the process along the way. My plans are to keep it stock, replacing all the bearings, rings, water pump, timing belt, all the gaskets. And anything else I find along the way that needs to be replaced. It will be for sale in the end, if you are interested in having me build it up to your specs let me know and maybe we can work something out. Please do not ask for me to part this out if you want the head etc, and please keep all sale talk out of this thread, lets keep this a technical thread. I will be happy to answer any questions you have about my build process!
