How to stroke a honda motor
My 16v is built along the same lines as this only with new highend parts. 93 golf bottom end , passat diesel crank, scirocco 16v head ex.
I don't know Honda #'s and letters, is this going to be Stroked 1.8 sohc 8v ?You ain't got no chance to beat it..like a man with no hands and a one inccchhhh .
Here is a dyno not sure you can see it
120whp with 9.7:1 CR I'm going to be at 11.4:1 so it will make a bit more
The main thing though is look at the tq! 100+ftlbs from 2000rpm to 7000rpm that's a pretty broad range that is hard to find in the Honda world
On your other question of what CR it will have you can pretty much set it to what you want, to get the pistons just about level mill the block .030 then it all depends on the head a y8 will put you a bit over 10.5:1 a z6 right around 10:1 use the calculator over on zeal auto works to dial in the CR you want
And if you have a gsr swapped car and it's stock I would love to test it out too!2008 Volkswagen .:R32Comment
well its kind of hard to find a stock one, as in airbox and exhaust, but I have a buddy that has one in a 96-98 4 door. I have seen a stock GSR dyno around 168whp and 122trq with an intake and a muffler. So well see how it goes. Let me know when your ready and well figure it outComment
I may be a boost/torque snob, but I haven't had a car make less than 250lb of torque @ 2k rpm in 12 years. I can't see myself being excited about 100lb/ft.. ever.
certainly not after a stroker/motor-swap.
again... I do get it.. and I always appreciate work like this, but it's funny to see someone excited for 100 lb of torqueCraig R.
'00 9-5 Wagon
Gclipse96 on AIM|Facebook.com/g96nt
sigpicComment
I get it... but I absolutely LOL'd at this.
I was going to say I'd run ya when it was done but guess that's put of the question now..You ain't got no chance to beat it..like a man with no hands and a one inccchhhh .
for some vids of how the motor turned out and how its running here are a couple of vids!
still needs a bit more timing in the top end I think I could add as much as 5* I made the basemap pretty conservativeComment
