How to stroke a honda motor
  • dan03235
    slow civic :)
    • 1404
    parts needed
    -d16 block, I used a y8 because it was free and still 75mm thanks brett bracket
    -d17 crank,rods, pistons the dx/lx pistons give a taaaaad more CR $75 bucks off CL
    -Rings for a d17 I went NPR
    -D16 main bearings I reused the d17 rod bearings $65 for both on ebay
    deck the block .030 you can go more but I have pics of what .030 looks like $50
    keep your #!#!#!#! organised shop towel and marker do wonders
    gap your rings accordingly If you are staying NA (PUSSY) go with stock specs per helms manual, since mine will be boosted eventually I went a little loose at .014 top and .016 bottom
    clock the rings accordingly (use endyne ring clocking pic) and throw those bastards in
    since I reused everything I kept it organised and cleaned it with carb cleaner
    put the bearings in with lube on bottom and on top
    crank goes it fallowed by plastigauge then the main gurdle. Oil up the bolts tq all of them to 18ftlbs then to 38ftlbs (I hope the sequence is obvious work from middle outward) remove it and check clearances.
    I lucked out and with std bearings (king) they all landed at .0015 but anything below .002 is OK if you are touchy about your clearances go with honda OEM bearings all STD, measure with plastigauge, then using the different color bearings dial in the clearance you want
    Hope you notched that gurdle! its TIGHT not sure if its needed on all blocks I also always clean up any casting flash to help the oil return to the pan
    all done
    for life d16 stroker will be killing stock GSR swaps all day long!
    Ill post up the oil pump, rear seal, and crank pulley setup in a bit!
  • dan03235
    slow civic :)
    • 1404
    the d17 rear main seal appears to match the d16y8 block perfectly all 4 bolts went in and the dowel pins all lined up how they should
    d17 oil pump is the same
    when I dropped the block off at the shop like most y8 blocks it came with a free spun bearing mod! so I gave him the y8 crank to use as a template
    timing belt gear fits like a glove
    crank pulley as well
    no i wont be using the light pulley already killed a motor due to using one so a stock a6 is going on or ill have a y8 shaved down....dont know yet what do you guys think?
      best thread ever, love it
      • dan03235
        slow civic :)
        • 1404
        thanks dag for around 200 bucks it will be making the same power as a stock 1.8l DOHC honda motor and will have a broader tq band
        only issue is the now 1.45 rod/stroke ratio its less then desirable but I just wont rev it to the moon and it will be ok im thinking 7200 or so it will stop making power so no point in going higher
        • N9nefiveAccord
          • 1455
          I've never heard of this before. Very cool, has this been going on for a while or is this something new and figured out?
          09 Titan
          06 Harley
          • dan03235
            slow civic :)
            • 1404
            I think the 1st one was done in 03 or so but people were scared of doing it due to the large number of parts used off different model engines
            I would say that fewer then 50 have been built online that I have found and nobody in the tristate area that I have found has built one. It's not 100% straight forward but if you want to build one this guide is a pretty good walk through.
            • tim1137
              • 790
              I read up on this a few years back too, seems ok, but alot of work for not alot of gain.
              2010 Nissan GTR Premium - Black on Black - Unmodified
              Everything else, sold.... jk I have a Miata too
              • dan03235
                slow civic :)
                • 1404
                I needed rebuilt motor anyway and the d17 was 75 bucks you can also use a b16 crank pulley and have no machine work done, for me it was cheaper to machine it haha
                  Pretty cool read man, keep this stuff coming!
                  • dan03235
                    slow civic :)
                    • 1404
                    Thanks I like using what people consider "junk" putting it together, and having something not done too often
                      As a "how-to" I think this should be in the tech section.
                      Great write-up man. I'd love to see more of this stuff on here.
                      • BLACK-OUT
                        OG Member #33
                        • 3957
                        i'd like to test this beating a stock GSR swap. Do you have a rough idea or a dyno sheet showing the power that this stroker should do? What will it bump the CR up to?
                        2008 Volkswagen .:R32
                        • dan03235
                          slow civic :)
                          • 1404
                          Here is a dyno not sure you can see it
                          120whp with 9.7:1 CR I'm going to be at 11.4:1 so it will make a bit more
                          The main thing though is look at the tq! 100+ftlbs from 2000rpm to 7000rpm that's a pretty broad range that is hard to find in the Honda world
                          On your other question of what CR it will have you can pretty much set it to what you want, to get the pistons just about level mill the block .030 then it all depends on the head a y8 will put you a bit over 10.5:1 a z6 right around 10:1 use the calculator over on zeal auto works to dial in the CR you want
                          And if you have a gsr swapped car and it's stock I would love to test it out too!
                          • dan03235
                            slow civic :)
                            • 1404
                            anyone notice what I did wrong on the build?
                            I kinda found out after looking at the pics lol
                            either way its been fixed now so its ready to drop in! just waiting on the VR6 swap to be done in manch so I can get the engine lift back and its going in!
                              You didn't build a K series?
