Torque Wrench General
  • Church
    needs to not mod crookedH
    • 354
    Since I'm not sure about the mechanical skill level of everyone on this site, I'm going to start a few "general knowledge" threads of advice for beginners. Some of you will probably already know this, but it might come useful to some people.
    Torque Wrench 101.
    1. General care and Storage:
    When purchasing a torque wrench, be aware to look up the manufacturers tolerance. This should be in a (+/- X%) marking. This means that when you set your torque wrench to a given value (e.g. 350 in/lbs) it will be within a range of that setting (a +/-5% tolerance will be anywhere from 367.5 to 332.5 in/lbs when set to 350 in./lbs). Generally speaking anything more than 3% isn't worth purchasing, as the tolerance tend to enlarge over time.
    When storing your torque wrench for any period of time (more than 30 mins is a good rule), do not leave it on the torque value you had last used. Instead bring it to the lowest value on it's rating, NOT ZERO. Bringing it to "zero" can loosen the internals and ruin the torque wrench.
    Every manufacturer has a set amount of uses per calibration of torque wrench they make. Keep track of this useage, when you are close to that number, or a year has gone by since purchase (which ever comes first) send it to the manufacturer for calibration. The internals weaken over time and need to be adjusted properly, otherwise your +/-2% wrench will become a +/- 10%.
    Do not, and I repeat do not DROP even onto a table your torque wrench, even a 1" fall can loosen components and make the wrench un-usable. If dropped accidently, send the unit in for calibration.
    2. Proper Application.
    When choosing to use your torque wrench, make sure that the wrench is able to stay within torque range. Using the Wrench example as above, a nut that is required to be torqued to 340-360 in/lbs would require a different wrench than above, as the wrench can either over-torque or under-torque the nut and cause pre-mature parts failure.
    A good example of where poor torque can cause pre-mature parts failure (and other issues) is a head install. Lack of torque will cause a head gasket to leak coolant/oil, which if cross contamination happens (coolant in oil) metal on metal movement and engine damage can occur.
    Always torque on the Nut, Never (unless specified or require aka VW/AUDI wheels which use wheel bolts not nuts) Torque on a Bolt head, the overall clamping force is always distributed by the nut as the threads of the bolt will bite into and bind against the material it is threaded into. By torquing a bolt head, you are twisting the head which creates extra resistance on the wrench. This means a bolt that you are trying to torque to 40ft/lbs of force may only have 30ft/lbs of clamping force on it. Torque rates for bolt heads already have this and thread stretch calculated into the rating.
    Using anything that extends the distance that the head of the head of torque wrench from point of torque (not a ratchet extension but for example a crows foot that extends the overall length of the "handle") increases the amount of torque put on a nut at any torque rating before the torque wrench will "click". I do not have the current formula on me and will copy it down monday from my General Tool Tech Manual, but you will need to measure the difference and input the desired torque to get what setting you will need to put the wrench at (I may even put up a diagram)
    diagram stolen from engineersedge.com
    Last thing I can think of, be sure to always double check the ratings and make sure you are following the right ones. It is very easy to accidentally read in/lbs as ft/lbs and vice-versa. I will also put up a metric-imperial (and vice-versa) conversion table when I get the leverage formula.
    2002 Audi Ur-allroad- Daily/urban soccer mom trap
    1990 Porsche 944 S2- Resto-mod/auto-cross slut.
    Good thread.
      I like the info. Thanks
      +1 rep for you
        Good info and I added rep as well. I have to slightly disagree with part of it though. The part about extending the handle is not exactly true. If you are using a torque wrench, it doesn't matter if you extend the handle or not since the torque application is read in the head (when it clicks). The head doesn't care where you are holding the handle. Extending the handle just makes it easier to move (for higher torque levels).
        I can see where one might think that though. If you apply 1lb of force at one foot from the center of what you are applying the torque to, you are applying 1 ft/lb. If you apply that same 1lb of force at the 2ft mark, it is 2ft/lb.
        Applying the same level of force at a point farther away from the center point would produce more torque. The ratchet will still click off at the specified torque value though so it really just makes it easier to reach that torque level.
        • Church
          • 354
          Absolutely true, but that's not what I was trying to explain. I've re-worded it for a clearer explaination. What I am referring to are attachments that extend handle length by moving the head further away.
            Ahh, I see. I misunderstood you.
            • Church
              • 354
              Hence why I edited it. Good thing you spoke up because I don't want to be accidentally mis-informing people.
                [MENTION=3378]k2500diesel[/MENTION] read up on this :P
                • The General
                  1994 Boosted Miata
                  • 1744
                  the only problem I have with this is by the time yours gets to you, wont it be #!#!#!#!ed up, I mean if you send it to the manufacturer even if you put fragile on the box. They are still gonna toss it around and if you buy one of these things at a store, who thinks they are taking care of so carefully or theirs wasnt the one dropped on the ground, that the dude just put it back on the shelf
                  MORE ON THE WAY STAY TUNED
                  • Church
                    • 354
                    Aren't they normally in cases and packaging? Which would still be better than dropping it on itself where it receives the full force of impact. I guess you could always purchase straight from Snap-on, Cornwell, or Harbor-freight where you know they only deal with tools and not have employees who wouldn't know about this abuse like sears or fedex/UPS.
                    My employer deals with snap-on directly. Expensive, but we have not from my knowledge Broken a bolt or had an aircraft go down from a "good" torque wrench that we didn't know was actually bad.
                    Either way yes, that is a risk, but I'd rather take care of my torque wrench that is probably in spec, than abuse it and have it 100% out of spec.
