inspection
    Originally posted by dexter_5000
    bring blocks of wood. would be my only suggestion so they can drive up on them.
    the third garage is a small ma and pa shop and they dont even have a lift..they usually do all the work for me and my familys cars.
    the other two were midas and meineki(sp?)
    • The General
      1994 Boosted Miata
      • 1744
      #32
      you should be all set to go in this place near where I live if you want, usually just check lights and #!#!#!#!. if you interested text me about it
      MORE ON THE WAY STAY TUNED
      • BustedassMark!
        • 424
        #33
        well i just went to get the miata inspected...3 diffrent places turned me down because my STOCK miata is to low to the ground to get a sticker..so does anyone know where i can go to get it done?
        try pro street unlimited in manchester its right off valley street... thats where all the honda kids go to get there rocketships instpected.... i mean ive been in the shop when he was doing inspections and he barely looks at the cars... if you have no check engine lights on and dont have a loud exhaust that you didnt buy from him you should be fine just call up and schedule an inspection and just be real casual and if he mentions something bout the rust just explain to him you plan on fixing in a month or so just say your tight on money and you should be fine....pm me if you want the number
        MY VTEC GOES BYE BYEEE!!!!
        • wayfast1500
          • 9
          #34
          Heath auto in Derry is good, only time he failed me was when I had a tie rod end way too far gone, and he didnt even reject it he just told me to come back within 10 days. I went back next day, just looked to see it was new and put a sticker on.
          • Ballistic Motorsports
            • 3403
            #35
            Dont fill the hole with spary foam or bondo . Your soft top drains there . If you fill it it will just rot higher and possible into the car . I would use sheet metal and have someone weld them up (or you could rivet it ). Just make sure you make a drain hole in the bottom . All Miata's have this problem .
            2013 Scion FR-s - DD/Shop Whore
            1997 BMW M3 - New HillClimb/Track car/Projekt M
            1995 Turbo Miata - sleeping right now
            Facebook Page
            "The corners are for fast drivers and straights are for fast cars."
            THE MOD FATHER ****Support our economy and buy Genuine products from me , not ebay knock offs .....
              good call! didn't even think of the drain.
