So I went to bump up my timing from 14 degrees, where I was running 87 octane to 16-17 degress on 93 octane. So I messed around with a bit since my dads timing gun was broken, and Mike couldnt find his. Ended up really messing it up. We had turned down the timing quite a bit. Then I messed around with it for awhile and eventually got it where I thought it was at 14 degrees.
As you can see from the picture where 14 degrees is, my timing mark on the opposite side of the pulley. I had not touched any timing of anything until that one time, when adjusting the timing it is only across a safe spectrum that is dependent on the CAS location, so it can not move the timing mark to where it is now. What would cause the timing mark or timing to move that far?
